What is mmWave 5G? Delivering Low Latency Mobile for Enhanced Performance
Experience the latest 5G mmWave technology for a strong internet connection, fast downloads, quick app responses, and ground-breaking speeds.
Arodi Dalpathadu
WRITTEN BY
Arodi Dalpathadu,
Sr. Product Line Manager,
CHP
  • Last Updated: January 29th, 2026
  • 5G mmWave: Low Latency for Mobile
    What is 5G mmWave?
    5G mmWave (millimeter wave) revolutionizes connectivity by delivering ultra-fast multi-gigabit speeds, enhanced capacity, and minimal latency. This cutting-edge technology, featured in the Nighthawk® M6 Pro WiFi 6E hotspot (and other hotspots featuring 5g MMWave), is perfect for seamless video conferencing, lag-free online gaming, rapid file downloads, and secure data sharing—even in high-traffic areas.
    Who Benefits from 5G mmWave?
    5G mmWave technology caters to diverse needs, including:
    • Content Creators: Stream high-quality videos effortlessly with ultra-fast speeds.
    • Gamers: Enjoy lag-free gaming with ultra-low latency.
    • Event Professionals: Set up temporary high-speed connections for seamless video distribution.
    • Small Businesses: Ensure secure, reliable internet for transactions, even on the go.
    • First Responders: Maintain critical communication during emergencies with robust connectivity.
    • Urban Dwellers: Experience fiber-like speeds in densely populated areas.
    • AR/VR Enthusiasts: Unlock immersive experiences in sports, education, and healthcare.
    Difference between 5G mmWave and 5G Sub-6 GHz
    Compared to the 5G Sub-6 GHz frequency bands widely available today, 5G mmWave delivers more bandwidth, faster WiFi speeds, and minimal delay when using heavy-data processing apps such as HD video. It has a shorter, more concentrated range that can only be accessed close to the tower, limiting the ability to penetrate walls*. 5G mmWave delivers better performance in crowded areas with a large number of WiFi users, such as outdoor festivals, construction areas, stadiums, and other public, urban spaces.
    NIGHTHAWK M6 PRO
    The next-generation technology after 4G LTE, 5G Sub-6 GHz allows users to experience the 5G higher performance and improved efficiency where mmWave is not available. It also has a longer range than 5G mmWave which allows the signal to easily reach inside buildings.
    With the Nighthawk M6 Pro that supports both 5G mmWave and Sub-6 GHz, users can enjoy all the advantages of 5G mmWave (where coverage is available) and seamlessly switch to 5G Sub-6 GHz and 4G LTE for full coverage when on the go or inside buildings.
    5G-Sub-6 GHz: A balance between performance and range.
    5G mmWave: Multi-gigabit speeds with lower latency at short range.
    5G mmWave download speeds
    What is the range of 5G mmWave?
    5G mmWave operates at high frequencies, offering blazing-fast speeds within a short range of up to 1 km (0.6 miles). However, its signal struggles to penetrate buildings, making proximity to the 5G mmWave tower and minimal obstructions essential for optimal performance.
    When using your Nighthawk M6 Pro, it is recommended to place it as close to a window as possible and in line of sight of the 5G mmWave tower to get the best signal. Conversely, accessing the 5G Sub-6 GHz signal is not dependent on where your Nighthawk M6 Pro is positioned.
    5G mmWave capacity
    Unlocked for ultimate flexibility
    NETGEAR WiFi
    The Nighthawk M6 Pro offers unparalleled flexibility with its unlocked design, allowing you to choose any carrier that fits your needs. Whether you’re at home or traveling across 125+ countries, enjoy seamless connectivity with a compatible SIM card and data plan.
    Work outdoors and in crowded areas
    Man and Woman smiling and a group of people in the field
    With 5G mmWave technology, the Nighthawk M6 Pro excels in challenging environments like crowded events and outdoor spaces, delivering reliable, high-speed performance where interference was once an issue.‡.
    FAQs
    What is a benefit of 5g mmWave technology?
    Compared to the 5G Sub-6 GHz frequency bands widely available today, 5G millimeter wave delivers more bandwidth, faster WiFi speeds, and minimal delay when using heavy-data processing apps such as HD video.
    What is mmWave 5g?
    5G mmWave (millimeter wave) expands 5G technology to improve the user experience with greater capacity, multi-gigabit internet speeds, and low latency, especially in crowded WiFi areas. These expanded capabilities are ideal for businesses and consumers to use for video conferencing in real time, online gaming, downloading large files, and sharing critical and highly sensitive data.
    Is 5G mmWave worth it?
    5G mmWave is valuable and ideal for anyone needing the expanded capabilities of 5G including businesses and consumers to use for video streaming in real time, online gaming, downloading large files, and sharing critical and highly sensitive data.
    5G mmWave range varies by use case and situation. 5G mmWave generally has a shorter, more concentrated range that can only be accessed close to the tower, limiting the ability to penetrate walls. 5G mmWave delivers better performance in crowded areas with a large number of WiFi users, such as outdoor festivals, construction areas, stadiums, and other public, urban spaces.
